Hood tool rack (pioneer tool rack)
Guys looking for suggestions and opinions on a hood rack that i am prototyping on my jeep. I know this is not for every one but this is more of an overland jeep build not weekend rock-climber. So i got this idea from the light weight pioneer tool racks on the Humvee's. After some different mount and rail shapes and about 20hr searching the internet this is what I have built.
The hood will have to be drilled and it will mount on the hood sheet-metal strengthening members (the cross x). I am planing on putting some rubber underneath to prevent scratching. The rack is made of 5052 Aluminum with stainless steel hardware. The actual tool brackets which i will have pictures of soon will be clamp type, two tools per rail side by side made of 3/16 steel with handle nuts for easy removal. I am still figuring on how to make caps for the end of the rails out of aluminum. If any one has any suggestions please comment.
Cool idea.. but... I just don't trust the sheet metal on the hood. A few years ago, I brought my jeep to one of those auto car washes. At the end of the cleaning, jets of air dry off the vehicle. My hood was bending and flexing everywhere. I guess I don't trust the bracing inside the hood with heavy tools. Are you thinking about doing some other bracing under the hood?
Nice idea !
I suspect that the hood is too weak and too flexible.
What may help is spreading the load & connections over a larger area.
For instance -- A casting of fiberglass between the hood and the aluminum will make the fiberglass follow the hood curve, the aluminum may sit flat on top of the fiberglass.
I'd then use 4 or 5 bolts along each side.
I concur, the "X" brace underneath should be a decent foundation, but only time will tell if it prevents flex from the significant weight of a sledgehammer.
I've seen steel hi-lift attachment brackets shear from constant road vibration, I know aluminum is easier to work with, I hope the boxed rails are up to the job. Maybe you'll need another rail with a dampner underneath the tool head to limit the bounce. All the best, it's a neat idea.
