Grenade shift knob
Old Oct 5, 2015 | 07:40 PM
doberman1911's Avatar
Default Grenade shift knob
I'm thinking about switching out the shifter knob for a grenade shifter. I think it looks cool, but primarily I think the weight of the grenade may buffer the vibration/rattle in the gear shifter it seems most manual jks are prone to have. Would there be any negative effects on the transmission if I switched out the knob? Anyone know of any other weighted gear shift knobs for the jk?
Old Oct 5, 2015 | 07:44 PM
Offroad_Elements's Avatar
Former Vendor
Not to rain on your parade, but I had a grenade shifter, had some decent weight to it. Kept popping out of gear, so I ended up going back to the oem knob. There may be a lighter solution out there - best of luck!
Old Oct 5, 2015 | 07:47 PM
Good point! I didn't think it cause the shifter to pop out if gear. Hmmmm.
Old Oct 5, 2015 | 08:17 PM
afpilot82's Avatar
JK-Forum Ambassador
I ran one for 2+ years on my '07 with no issues and will be switching it over to my '15 as soon as I get around to it.
Old Oct 5, 2015 | 08:31 PM
Former Vendor
Do you have a link or more info? I really haven't looked much after my first experience. Is it fairly light?
Old Oct 5, 2015 | 09:36 PM
I'm interested as well.
Old Oct 5, 2015 | 09:39 PM
afpilot82's Avatar
JK-Forum Ambassador
http://m.quadratec.com/products/prod...?pid=96117+701
Nothing fancy, the lemon grenade fits great in the palm of your hand and there are 3 set screws to keep things tight.
Old Oct 6, 2015 | 04:39 AM
RubiKing's Avatar
I made one for my old YJ, it was very uncomfortable. Went back to stock.
Old Oct 6, 2015 | 05:46 AM
Just some weights I pulled off of Wikipedia:
M67 (baseball) -.875 lb
M26 (lemon) -1lb
MK2 (pineapple) 1lb 5oz
I like the baseball but wish it mounted on its side. I may go with the lemon.
Old Oct 7, 2015 | 03:25 PM
mack2's Avatar
I've had this pineapple on mine for 3+ years. it's a dummy I drilled out and tapped a set screw into, it's rather heavy and haven't experienced any issues yet, I did remove the spoon and primer apparatus because it was rather uncomfortable
