Jks rear shock relocation
Does anyone have any feed back on using these jks relocation brackets? I bought a set and I was thinking about the rebound and compression of the shock. Will that affect road worthiness? I know I smacked that part of my axle a few times on a few rocks so I'm eager to put them on and try them out. Any info is appreciated.
All they do is raise the lower mount which will result in less up travel and more down travel in the suspension. Ride quality should not be affected unless you bottom out the suspension easily.
Have not seen the JKS ones until now. Not trying to rep or push evo stuff but there rockstar skids and relocates are nice and beefy for cheaper. When i went this route i had to change my bump stop pads to keep the shocks from bottoming out.
EVO: Bumper/Armor/Skids, Rock Star Skids by EVO MFG.
Keep in mind that when you lean the shocks over that they won't operate and move quite as they're designed. Even when you move the shock, you want it to still move freely as you cycle the suspension and go for the "flex" everyone seeks.
