35" vers 37" tires with 488 gears
Would like some advice on 35" tires vers 37" tires. I have 2011 jk Serra with 488 gears, 4" lift with XRC mod bumpers. Time to buy tires and other than the weight difference , wheel clearance what should I be aware off if I move up to 37" tires?
You have the 3.8 and from my understanding you would want to run 5:13's if running 37's and 4:88's with 35's. It's probably tolerable to move up to 37's but you will have some power loss if you're running an automatic. Don't forget you'll need a ProCal or other calibration tool to get your shift points and speedo correct.
I'm running 4:88's with 37's with the 3.6 and its perfect.
If you have a manual tranny then you should be just fine. I am riding on Pro Comp, Extreme's 37's with 4:88 and manual and it is perfect. I have a 2011 with the older engine, so you should be just fine.
a 2007 JKU with 34s (315/70/17) and 5.13s and it did just fine both on and off road...
