Teraflex Knuckle Gusset Question
I am installing Teraflex knuckle gussets this weekend. For those of you that have installed these gussets, was it necessary to remove the coil springs?
I am running 2.5in TF coils.
I put a set of those in before. I did not remove the springs. Some areas were tight to get into but still able to. I should add, I did not removed the ball joints either, just keep moved around and let the area cool when working closer to the ball joint area.
I appreciate your input, thanks. I am replacing the ball joints so no worries there. I mainly don't want to have to loosen all the control arms, pull the springs, and re-torque everything if I don't have to. I remember hating that process when I did the lift.
To answer your question, no, but it'll make it easier and only takes a minute.
