Small diameter driveshafts.
Old Apr 19, 2016 | 05:59 AM
Jeeptang's Avatar
Default Small diameter driveshafts.
I have grease being thrown from the CV shaft close to transfer case in the front. Anyway I also have a torn boot from the exhaust.
I saw that Adams makes a 2" driveshaft. Wondering if anyone else does. The more clearance the better.
I'd like to get rid of that CV joint also if possible.
I was thinking 1310 yokes and I guess the non greasable slicer is stronger? I've been reading up on this and undecided on what to do.
Old Apr 19, 2016 | 06:48 AM
TheDirtman's Avatar
It should be stronger due to it not having a hole thru it. Most aftermarket driveshafts have a small diameter body. The greasable ones are fine and proper gearing in terms of tires size is a consideration if you want to keep from breaking u-joints.
Old Apr 19, 2016 | 04:33 PM
zstairlessone's Avatar
I think, and may be completely wrong, but the strength you look for in a driveshaft comes from allowing it to twist as torque is applied and I think (again with the imho disclaimer here) you are better off with a hollow tube shaft. Of course the shorter a shaft is the less this may play into it, but.....
Old Apr 20, 2016 | 02:23 AM
larry0071's Avatar
He is referring to the U-joints being solid vs being cross drilled for grease, not the drive shaft tube itself.
A solid body Spicer is stronger than a cross drilled. If you have a cross drilled greasable joint with a grease fitting in the web, indexing the grease fitting correctly is a must-do for strength. You want the grease fitting in compression, not in tension. It makes a huge change in the breaking strength of the joint.
Old Apr 20, 2016 | 04:05 AM
Jeeptang's Avatar
Jeep is a Rubicon with 4:10 gears. Later I'm planning on 5:13s. But as of now trying to figure out what front driveshaft to use. And joints.
Old Apr 21, 2016 | 05:02 PM
Jeeptang's Avatar
Dropped it off at the dealership. Going to see if they will warranty this one. They have done some stuff in the past. I'll still do an aftermarket one but at least I'll have a good back up or something to sell later.
Old Apr 22, 2016 | 04:46 PM
Jeeptang's Avatar
Well as you would have guessed. No warranty for this.
Ordered an Adams front shaft from northridge 4x4. 1310 yokes
Old Apr 23, 2016 | 05:35 AM
HV's Avatar
HV
Cool
Hello
you had mentioned Adams Drive shafts , recently I had ordered a drive shaft from them and the FEDEX idiot tossed it over a six foot fence ( i,m not kidding) it weighs close to 40lbs . I called back Dan at Adams explained the situation to him. with no hesitation he had a new drive shaft made and shipped next day air in less then 24hrs at no charge , i had my new rear drive shaft . Amazing product and customer support if your looking for new drive shafts for your rig TRUST ME there the best in the business. I'm running front and rear Adams 1350 drive shafts on 38s 0n 488 and it is smooth no vibrations at any speeds even High speeds Thank you Dan & Adams drive shafts simply the best
Old Apr 23, 2016 | 06:31 AM
Jeeptang's Avatar
That's good news. I'll probably do 1350 in the rear someday. It shipped the same day i purchased it.
