Lightbar
Old Apr 19, 2016 | 06:31 PM
ricky7458's Avatar
Default Lightbar
So a friend of mine is offering me his brand new never used ridged light bar and light. I'm debating on putting it on or reselling it, is the whistle really that bad?
Old Apr 19, 2016 | 07:10 PM
Rubicon Beast's Avatar
I have a different light bar (50" KC LED), but I can say that the only time it has ever made a whistle was after it got turned up after a drive through car wash.
Old Apr 19, 2016 | 07:27 PM
Flex_Junkie's Avatar
The whistle can be fixed.
Old Apr 20, 2016 | 03:31 PM
ricky7458's Avatar
do you know how?
Old Apr 20, 2016 | 06:28 PM
do you know how?
Not a 100% permanent fix yet, but if you cover the sides with something to keep air from flowing through it will not whistle. I just have some electrical tape over mine, haven't had the time to take it back off and come up with a permanent solution. But mine makes zero noise. I also used some door edge trim on every fin, but it wasn't until I covered the sides it went completely silent.
Old Apr 20, 2016 | 07:12 PM
numbah1's Avatar
Vet Army
Get yourself some 7/8" windshield washer nozzle line and cut it into 6" strips. Use a small screwdriver to push each strip on alternating fins (one and each side and along the middle portion).
These can be found at your local auto parts stores for less than $6.00. Easiest fix ever.
Installed my light bar over 2 years ago and never had a whistle from day 1.
Old Apr 23, 2016 | 11:26 AM
Jeepgeek15's Avatar
Would you guys recommend the single straight led light bar or the multiple singular circle lights?
Old Apr 23, 2016 | 01:30 PM
ttechris's Avatar
Default Whistle
The whistle can easily be fixed with some weather stripping, but I have never been able to get rid of the flapping I get with a soft top and a light bar on the highway.
Old Apr 23, 2016 | 03:00 PM
mhockey9090's Avatar
Vet Army
I used 1/4 irrigation tubing cut into pieces and put between the fins.
Old Apr 24, 2016 | 05:39 AM
POLARIS PRO's Avatar
Or just get something like this. Some guys stated they did the trick. Light bar not at the top of my list yet.
