Flighty steering after lift.
I installed a Teraflex 2.5 coil lift about 3 months ago and did the steering stabilizer at the same time and went up to 33s. I was hoping i wouldnt have issues but on the interstate it feels like im trying to fly my jeep rather than drive it. Whats the cheapest way to regain the tighter steering and handling?
AEV control arm drop brackets will be the way to go without having to buy adjustable control arms. I've been using them for 2years with a 3" lift and it definitely makes a difference. Look in the for sale section you may find some available. Good luck.
A third vote for caster correction.
Have you had it aligned? If so, post the numbers for us. If not, call around to a few shops. Some will do free checks where they just throw it on the rack and print the before specs. Stock caster is around 4 degrees, yours is probably around 3.
The pinion rotates up with the lift, which lowers the caster, which causes the flighty steering. So the 'fix' is to rotate the pinion back down. The choices are Cam Bolts, Drop Brackets, or a set of either Longer/Shorter Fixed control arms or Adjustable control arms. (or chopping up the housing or buying an aftermarket housing...). There are pro's/con's, so look past the prices and do some research on which option is right for you.
I'll vote for castor correction as well. If it feels like your steering is lagging, you may also need a new heavier duty track bar. A loose track bar will flex and move as you drive down the highway.
Metalcloak makes a braket does the same as the RC and AEV has 3 different mounting holes for the UCA like the arc as well so if later you want to step back to lower height you can with theirs. the place theirs stands out is its not two separate plates and is boxed in, IMHO easier to install trying to hold one piece in place to bolt instead of 3. Have them on my rig and install was a breeze... With a touch over 2 inches lift barely notice a difference from stock handling
I will answer that question, but the reason no one else has is because that answer is NOT recommended for a Jeep that is driven offroad. Camber bolts. They work great in cars that are highway driven and not subjected to offroad vibrations and articulation. If you go offroad, then you'll end up having to weld up the damage from installing the camber bolts when they loosen up, and do a proper fix (as described in the several answers above this one). The reason I'm answering this question is because if you go to a typical alignment shop and ask that question, they will recommend them. So you need to be informed.
