BEWARE: Rampage Hood Bra Eats Paint
So I just bought a Rampage Hood Bra about 3 weeks ago because it's spring here in the northeast and I wanted to protect my hood from stones. I had the thing on about 2 weeks and removed it for the first time today to wash some pollen off of my car. I was horrified by what I discovered.
The dye or material... or something... had eaten away at the paint of my car. At first I thought that it was just something stuck to it from the product but, after close inspection, it was clear that something in the Bra had interacted with the paint and caused it to fade blue. I am so mad.
Rampage has been responsive so far but if I dont get compensation to repaint my hood, I'm going to be so angry.
Just wanted to post this so others car watch out. See pictures below.
Never really saw the draw of a hood bra. Aesthetically it does nothing for me and I've heard, regardless of brand, that hood bras will eventually fade the applied area no matter what part of the country you're in or how much sun it's getting.
Agreed... but 2 weeks isnt enough time to fade anything. It definitely ate away at the paint, it's like this weird blue color.
Serves me right for getting a bra or anything from Rampage, I guess.
That definitely sucks.
Any potential it could just be some kind of moisture which will clear up once the sun bakes on it and the moisture dries up?
The reason I ask is because by looking at your pictures, it seems like the top clear coat looks relatively untouched on top of the dis-colorization. So it seems like if the paint was truly messed up, the top clear coat would be as well.
Def not moisture. The clear coat does look alright in the pictures but when you touch it, you can feel that it isnt exactly the same texture as the rest. Less smooth or something. Real strange.
I generally avoid hood bra's since all they do is trap dirt and moisture and make the situation a lot worse over time. Every vehicle I've seen long term that has had one of those has awful rusting underneath it from the bra vibrating any dirt through the paint and just wearing it down while it holds a nice damp surface underneath.
What you have those is flat out funky though. It shouldn't happen anywhere near that quick. You could try giving them a call and see if they know anything about it.
Could it be just some dye on the clear coat that could be removed?
And its a Jeep, not a car
Trapping water/dirt particles against the clear coat can cause the clear coat to get foggy. Magnets can do the same thing. Depending on how deep it goes it may be able to be buffed out. This is based solely on what I've read as I never have had it happen to me because I was aware of the issue and therefore never used a product that could trap moisture against my paint.
