Jk Storage Questions
Anyone on here store there JK for a long time (like 6 months) and had any issues? I have a '12 JK 4.5" AEV lift, axles gussets- gearing redone with winch a synthetic line. I just covered it, pulled battery and filled the tank. Am I missing something or should I watch for something?
Driving a Audi A4 Quattro as a DD.
Use the stabilizer or you will gum up your fuel system. Buy a battery tender, disconnect the battery and hook the tender to it. If possible make sure mice can't get to it or they may chew the wiring (make sure it is vacuumed really well or ants may also become an issue), I used to put vehicles on jack stands but there really is no reason to.
You absolutely should use stabilizer. Modern day gas has ethanol, which really sucks. I have first hand experience of ethanol cause my floats to stick on ATVs after only a month in storage. Any boat owner will also tell you how bad ethanol is during storage.
Also, I would have put the battery on a trickle charger rather than remove it. If the battery goes weak, it can freeze which will ruin it.
My son's TJ spent two NJ winters sitting in my driveway. One while going through Marine infantry training and another while he was in Afghanistan. I had stabilizer in the gas and had the battery connected to a trickle charger, without the battery being disconnected from the Jeep. No problems with it when my son returned.
