Hydro Assist (WTO) Steering Feel & Return to Center
I am looking to upgrade to a Redneck Ram system soon on my 07 2DR JKR with 37s. What is the steering feel with hydro on a 2 door vs without. Does the steering still return to center without manually moving it there? How does bad caster affect the steering with hydro compared to without?
My main reasons for upgrading are for easier steering in the big rocks and to relieve stress on pitman arm and sector shaft. I've seen a couple break on the trail and its a nightmare. Also after 108K miles of rocks and dirt the box could definitely use a rebuild, I intend on going with the stage 2 kit. Anyone installed a WTO kit and would have done something different? I intend to add an inline cooler, otherwise will run what comes in the kit w/ 1.5" Ram.
Everything you are saying makes sense and are on the right track. That 1.5 ram works great with the stock pump. I've gotten my jeep up to 90 mph with one finger on the wheel. On the rocks with heavy 37 trail grapplers is effortless to say the least even locked front and rear you can turn a little just don't force it. Get a single pass heatsink cooler. I use a 17" one. I don't trust the lines from WTO so I made my own using aeroquip hoses and fittings. You can use the hoses WTO sends you as trail spares. WTO are good peeps and do good work. I've been running the system for 2 years with no problems. The steering does still return to center but slower than stock
Edit -I agree with Monte, either get your own hoses or ask for hoses that are 48".
I'm wondering if I'm not getting enough flow or something... mine still takes a good amount of input to turn, and in rocks I still have to rock the jeep to get it to turn. Over bumps and such my steering wheel still moves. My tires are a bit imbalanced and the steering wheel shakes. Any recommendations?
You should be able to push 500 lb rocks around while not moving.
