T-case font output yoke play
I have an adams driveshaft and when i push up and pull down i can feel the hole shaft moove.... dialed it and its around 1.3mm.
I did not check the runout and my tires was terribly out of balanced so i didnt noticed no vibration other than the tires. So when i swap for new tires, I new something else were vibrating... looked at the driveshaft and there wasa 0.020 of an inch runout!
Rotate the DS 180 degree in the yoke and 0.003 runout but at this moment i noticed the play so maybe my DS killed my bearing... am i crazy or this would make sense?
