Coil rubbing on steering box bolts
Old Mar 7, 2017 | 10:55 PM
Jeek.OlllllllO's Avatar
Default Coil rubbing on steering box bolts
Anyone else have this issue? I can't figure out how to fix it with out grinding down the bolt.
Old Mar 7, 2017 | 11:10 PM
jedg's Avatar
Vet Army
Perhaps a photo or two?
Old Mar 7, 2017 | 11:13 PM
Probably should have been more specific, when I'm flexed out it rubs at full bump
Old Mar 7, 2017 | 11:15 PM
Don't have any pictures I'll take some tomorrow
Old Mar 8, 2017 | 03:45 AM
sa29560's Avatar
What length are you running your lowers at?
Seems to be about the only way it's pushed out far enough to touch. Mine are at 23 and a hair but there's still a tiny gap when it's all stuffed up.
Old Mar 8, 2017 | 04:00 AM
BrowniesJK's Avatar
I'm having the same issue. Started squeaking a few weeks back. Mine is even happening during daily driving. My alighnment is spot on so not sure what the issue is. Maybe a sagging coil?
ID:	667900   Click image for larger version
Old Mar 8, 2017 | 04:20 AM
Biginboca's Avatar
I've had this issue. I had to shorten my front lower arms a tad, just under 23". And I ground down the bolt head some with a grinder.
Old Mar 8, 2017 | 04:22 AM
austin160's Avatar
Vet Army
My front right was rubbing on the sway bar when flexed. I replaced it, and it still does it. Lower control arms is the only fix I can see for it.
Old Mar 8, 2017 | 06:38 AM
your axle might now be centered
Old Mar 8, 2017 | 06:41 AM
might give that a try, I'm like 1/8th longer than stock I believe. But I need it where I'm at for pinion angle.
I have the Jks sector shaft brace so that makes the bolt stick out like a 1/4 inch more I think
