What should I do next to improve ride quality
Old Mar 13, 2017 | 07:59 PM
Dunejk13's Avatar
Default What should I do next to improve ride quality
13 jk 2 door auto
So far I've got aftermarket steel bumpers with winch and tire carrier
Jks disco
Teraflex rear trackbar bracket
Rear brake line brackets
Rock hard engine trans skid
Teraflex 9500 shock I wanna say
Ome hd springs
Need to install front lower control arms still
Do you guys think it's worth doing front and rear trackbars
The ride is very floaty
Or what else do u recommend
Thanks guys
Old Mar 13, 2017 | 08:08 PM
shabbernigdo's Avatar
its a jeep its pretty much always gonna have the floaty feel to some degree. I have the aev 2.5 on mine and its suposed to be one of the best out there for on road manners and it still has the float feel just to lesser extent.
Old Mar 13, 2017 | 08:41 PM
Tilly's Avatar
The biggest change for me after I installed my ome lift was lca and ball joints. I'm sure the trackbars and everything else made a difference but I couldn't tell as much with those
Old Mar 13, 2017 | 08:53 PM
jedg's Avatar
Vet Army
What do you mean by the 'ride is very floaty'?
As in the steering is floaty or that overall the suspension feels floaty?
If steering, perhaps you've got enough lift (you didn't say and it's not in your profile) that your caster is out far enough to make the steering feel 'light'.
Old Mar 13, 2017 | 09:38 PM
nthinuf's Avatar
Originally Posted by Dunejk13
Ome hd springs
You answered your own question.
Those HD coils gave a bit over 3" of actual lift height, correct? With stock arms, the axles rotated, raising both pinions. Up front, this automatically lowered the caster, causing flighty steering. Get some form of correction for that first. (Not an issue with 4-doors, but many with 2-doors choose to go ahead and adjust the rear pinion as well.)
After that, a raised rear trackbar bracket might be a good call.
And then, if you want to center the front axle, get an adj trackbar. (Or, do some research on draglink flips.)
Old Mar 14, 2017 | 06:12 AM
numbah1's Avatar
Vet Army
This.
Don't forget to get an alignment after this is done to get it all dialed in.
Old Mar 14, 2017 | 07:22 AM
karls10jk's Avatar
Please define "floaty".
I'm running similar coils with a rear TB bracket, front TB, lower control arm drops, and Rancho 5000x shocks, 34psi and I don't feel floaty at all. It's not factory but it's good for being lifted.
Old Mar 14, 2017 | 07:50 AM
jedg's Avatar
Vet Army
Yup... this is why I asked the same question...
Old Mar 14, 2017 | 03:04 PM
Dunejk13's Avatar
It's hard to explain like moving side to side in the lane
Think I'm going to install the control arms and see how it feels
Old Mar 14, 2017 | 05:20 PM
karls10jk's Avatar
What does your tire pressure look like? What about the actual tires themselves?? What condition/ age/ mileage is on your shocks?? And why is it that you're pushing towards lower control arms? Throwing parts at it won't solve the issue, it'll just be a more expensive issue.
