Evap system leak and repair.
Old Apr 8, 2017 | 12:49 PM
Sabotage70's Avatar
Default Evap system leak and repair.
I've had I small leak code that would pop up every couple of months or so. Then I ran a pretty hard trail and must have slammed down on a rock. Because the gas cap code came up after that.
While crawling around underneath trying to see anything I grabbed something and it snapped.
By the looks of it, it has been cracked for a while.
Of course the white cap that the evap system lines connect to can't be replaced. And the last thing I wanted to do was buy a >$700 gas tank.
After thinking of a fix, I came up with an inner sleeve. Unable to find anything that suited my needs at a couple of hardware stores; small thin walled tubing. I remembered that hobby shops(rc and model) have various shapes and sizes of brass and aluminum. Picked up a 2' of 3/16" × .014 aluminum tubing for $5.
Back to the hardware to get a 3/16" drill bit and some apoxy.
I cut a 1/2 inch off off the tubing and drilled a 1/4 inch into both ends of the break. Be careful that the bit doesn't pull itself in to deep.
Deburred the cut end.
It's a bit of a snug fit. But shove the sleeve into the hose side first. Then into the tank side.
I used gorilla glues clear epoxy after scruffing the connection a bit with some scotch brute.
I couldn't have been happier with the results. I think I spent less than $15. But even if you have to buy everything including a small cheap cordless drill. It's still cheaper than buying a new tank.
