Sway Bar Disconnects: Does Length Matter?
Old Jun 25, 2017 | 10:55 AM
jhol111964's Avatar
Default Sway Bar Disconnects: Does Length Matter?
Just installed some Steinjager J0030554 Quick Disconnects, and at minimum length, they are about 1/2" longer than the stock links:
They were sold to fit 0" to 2" lift. I'm a little disappointed they aren't adjustable to exact OEM length, but I'm studying the anti-sway bar and clearances, and can't really come up with a reason 1/2" matters. Any concerns?
Old Jun 25, 2017 | 11:52 AM
mhockey9090's Avatar
Vet Army
Just cycle the suspension and see if it hits anything on the way up, doubt it will. I wouldnt necessarily be concerned with it unless it was going to hit something but then again I haven't had mine connected for 2 years.
Old Jun 25, 2017 | 12:56 PM
spinuck's Avatar
Attachment 672784
Assuming you're going to disconnect them when off roaring/flexing, it won't make a difference.
Old Jun 25, 2017 | 01:16 PM
nthinuf's Avatar
Rather than telling us how long the new links are compared to the stock links, how parallel to the frame/ground are the swaybars?
The usual recommendation is to have those bars +/- 5 degrees from parallel, with an upward angle being better than a downward angle. Having the swaybars sloping steeply down, especially when running longer shocks, can cause the swaybar to flip around - which generally gives a nice photo op...
This is of course assuming that you are drooping the suspension without disconnecting. Like on a lift at the shop, as a few people have found.
Old Jun 25, 2017 | 07:23 PM
rsmwrangler's Avatar
Like it was said, just check that the links have enough clearance when the cycle.Other than that, 1/2" won't matter much.
Old Jun 26, 2017 | 06:00 AM
bbolander's Avatar
This is the key. The installer on my prior LJ had the sway bar ends pointing downward and the bar flipped to forward. Some upward angle on the sway bar ends is best.
Old Jun 26, 2017 | 02:53 PM
jhol111964's Avatar
Quote Originally Posted by nthinuf View Post
I looked, and its pitched up about 1/4" over the 12" moment arm span, for an angle around 1.2 degrees. If the originals are 1/2" shorter, that would mean it was pitched down before I added the longer disconnects? That doesn't sound correct. Any ideas how that can be? Not sure what's going on, but it appears to be functional as-is. Also, I drove it around and at highway speed disconnected - reminded me of my old CJ's.
Old Jun 27, 2017 | 07:44 AM
resharp001's Avatar
Loved
Community Favorite
Sway bar link length doesn't need to be an exact science. You'd much rather have it angled up just a bit than down as previously mentioned. There is nothing wrong with how it is now having the links be just a bit longer than what was on there before. The only real difference you're going to tell is how much more pleasant disconnecting is!
Old Jun 28, 2017 | 03:20 AM
jhol111964's Avatar
Absolutely correct - much much smoother ride. Since disconnecting this weekend, I've taken ramps at speed, commuted 30 minutes via interstate, crossed the ditch in my front yard to load up some equipment at the front door, etc. I'm driving with respect, not to create a heavy roll situation, but the rear swaybar appears to add plenty of control. Thanks all for the advice -
