Mismatched Gear Ratio Question
Picked up a used prorock front 44 on CL. It has 4.56 and I run 4.88. I'm almost certain but want to confirm the following before driving anywhere: As long as I dont engage 4WD I can run the different gear ratios front to rear even with front shaft installed with no issues. I just need to run a few errands and then drive to the gear shop to have the regear done...
Thanks! I was thinking that at first also, but the the WSS read at the wheel in the unit bearing independently of each other. I was worried about the transfer case but it looks as though in 2wd there is no physical connection anywhere between the 2 axles drive trains.
I had my front driveshaft connected while my rear was 3.73 and my front was 4.10...drove it like that for 2 months until I had both regeared.
