37" Nitto Trail Grapplers, or your Tire Brand... What is your street PSI????
Old Aug 25, 2017 | 01:48 PM
YukonBlu's Avatar
Default 37" Nitto Trail Grapplers, or your Tire Brand... What is your street PSI????
What are you guys running your Street PSI at on your 37" Trail Grapplers? Or if you are running 37s in general? Curious what everybody is running. Just asked about the Trail Grapplers cause that is what i run. Thanks everybody
If you could list:
Wheel Make/Model and Size:
Tire Brand and Size:
Thanks
Ready GO.....................
Old Aug 25, 2017 | 02:11 PM
AnvilX14's Avatar
Ballistic Jester 18" wheel
37x12.5 Federal Couragia load E (10 ply)
32 psi
Old Aug 25, 2017 | 02:12 PM
MacRubi2's Avatar
37X12.5 ProComp Xtreme MT2 load range C run them at 30psi on the street
MT Deagan 38 17X9 Pro 4's
Old Aug 25, 2017 | 07:17 PM
MTNBKR's Avatar
Kmc Machete 17"
37" Trail Grapplers 27.5 psi
Old Aug 26, 2017 | 04:56 AM
kjeeper10's Avatar
Vet Army
Nitto RG's 27fr 26rear 37x12.5x17
Old Aug 26, 2017 | 07:50 AM
Ryan0260's Avatar
I run 28 psi in my 37" Ridge Grapplers. They are D rated. I ran 26 lbs in my last set of E rated Trail Grapplers. A chalk test is the best way to figure out the best pressure, as tire load ratings and vehicle weight make a big difference.
Old Aug 27, 2017 | 01:22 PM
YukonBlu's Avatar
17" ATX Slabs
37" Nitto Trail Grapplers - 30psi on street.
Have not done the chalk test... im gonna look into this. Thanks
Old Aug 27, 2017 | 04:19 PM
scooby snacks's Avatar
I run 32 psi in my 37" Nitto Ridge Grapplers. I ran the same in my 37" Toyo Open Country RTs.
Old Aug 29, 2017 | 01:40 PM
YukonBlu's Avatar
I have never run tire pressure this low before... is 30 and under PSI on the street what Nitto recommends with these tires? Before my current 37s the biggest tire i had run was a 35.. even then i think i was running at mid 30s. From the looks of it, and i have not done a chalk test yet, but i may have to drop down to around 26 or 27psi.
Old Aug 29, 2017 | 01:49 PM
mdash's Avatar
2 dr JK
17x8.5" Trailready Beadlocks
37x12.5 Goodyear MTR's
24 psi front and rear on the street
