Bolt Size for Rear OEM Bumper help???
Old Sep 1, 2017 | 11:35 AM
mhockey9090's Avatar
Vet Army
Default Bolt Size for Rear OEM Bumper help???
I got rid of these bolts in the OEM location and need to pick up a set for the currie rear anti rock install. Just realized they used the OEM ones.
Does anyone know? Thank you!
Old Sep 1, 2017 | 11:59 AM
ronjenx's Avatar
Try this: M10x1.5x30
The parts book does not clearly show if these are the bolts you are after.
Old Sep 1, 2017 | 05:48 PM
Vet Army
Thank you. I am going to buy a set of grade 8 bolts but my buddy reached out to me and had a set laying around.
Old Sep 1, 2017 | 09:09 PM
jordy's Avatar
Loved
Community Favorite
Depending on your setup, mock it all up and check clearances. You may have to take a grinder to that outside shoulder in order to clear the control arms that run to the axle. Ran into that on one where it looked good, started to snug things down, and it was toed in. Had to take it all back apart, grind the shoulders and put it back together. This was on a JKUR with the factory D44's. The destructions mention the possibility, but aren't that clear.
Old Sep 4, 2017 | 08:37 PM
Vet Army
Everything appears to be golden. Just going to run without the links until everything else comes in to button up. Its been interesting so far without them.
