Pressurized Foot Rinse System below JK Doors
So ever since I made the pressurized running water rear bumper system on my JK years ago, I wanted to add nozzles under each door with electronic valves to wash my feet before entering the JK fully. So yesterday was the day, and I personally enjoy the mod and thought you all would as well.
Since the way the pressurized water pump works is by turning on only when the nozzle is open (because it detects a pressure loss in the line) you can put lines anywhere with valves and it will all work off a single pump. So I tapped into the output hose and ran 1/4" water lines throughout the underside of the Jeep to electronic valves controlled from inside each door on the B pillar.
Best way to explain it is by video which can be seen here!
