Tie Rod Replacement
I need to replace my tie rod ends should i just replace the stock ends or upgrade to a stronger Tie Rod altogether? I have a 2012 JKU Rubicon running 37's.
Be glad that TR made it this long. Time to start upgrading your steering
. If you're even the least bit handy (ie. you can install yourself), you can "build" a nice aluminum TR either via Rought Stuff, or even cheaper (more of a DIY) like this -
https://www.jk-forum.com/forums/modi...ie-rod-346539/
TR's usually aren't cheap, but they don't have to cost an arm and a leg. Whatever you do though, definitely something that is better than stock if you're running 37s.
. If you're even the least bit handy (ie. you can install yourself), you can "build" a nice aluminum TR either via Rought Stuff, or even cheaper (more of a DIY) like this - https://www.jk-forum.com/forums/modi...ie-rod-346539/
What they said upgrade it. MOOG makes a decent tie rod with lifetime warranty that you can actually grease the ball joints on. You're in my neck of the woods so if you wanted an assist to DIY ping me.
