[Installation]: Teraflex 4'' Adjustable Sway Bar End Link
Pretty sure your Tech was right and the rear links should have been moved to the front during your initial lift install. But that being hindsight, I found the JKS disconnect to be easy install. You also want to be able to disconnect for trails so not sure why you would want one that is not easily disconnected.
