2012 jk hub assembly
Hi all new here and first post.
I am in the process of replacing my drivers side front hub assembly. I was able to remove 2 of the 3 Hub bolts but the 3rd snapped... My question is there only threads in the hub or are there threads is the knuckle. Will I have to drill that bolt out?
thanks,
jeff
thanks,
jeff
+1 on buying new bolts! Also, I would suggest a more "premium" 12 point socket for these... I have found that my cheaper sockets are more likely to mess up the head of these bolts; so I bought a Snap-On version and it did a great job when I torqued these bolts to spec. Also, make sure to use some thread locker blue on these bad boys.
