Crunching on Articulation
2013 2-Door Rubicon-Just had a complete 2-1/2" Rock Krawler lift installed. During Jeeptoberfest while riding the Modified trail with electronic sway bar disconnected. there developed a very pronounced crunching noise in front while running over obstacles. Reconnected the sway bar and noise seems to have gone away. Previously with sway bar disconnected on stock suspension had no issues. Is it possible that the increased articulation was too much for the electronic sway bar and I damaged it internally? Any suggestions as to whether the noise was related to some other suspension component?
Check to see if the sway bar is rubbing on the tubes that prodtude thru the frame. With the extra articulation the axle shift is more pronounced. The disconnect should be fine as it will spin 360 if it had nothing to stop it while disconnected.
