Steering is terrible.
Old Jan 16, 2022 | 06:45 PM
Big H's Avatar
Default Steering is terrible.
I bought a 2011 2dr jk sport it had a 4in lift I think. I'm very new to this. And 35's. I started getting a low speed death wobble,so I completely rebuilt the front end. And the steering is worse than it was. No wobble, it just wants to take off when it hits a rut in the road . Any help would be greatly appreciated! Thanks
Old Jan 17, 2022 | 05:00 AM
Schlieko's Avatar
For me, hitting a pothole and having trouble is the ball joints. Having a bobblehead, floating feel to steering is hubs and bearings. Finally, I will check each shock to make sure one is not blown if everything else is good. I have been recently been thinking about increasing caster just to see if it makes any significant difference.
Old Jan 17, 2022 | 10:27 AM
hornetman's Avatar
Veteran: Navy
Rebuilt whole front end? What exactly did you rebuild and what parts did you use? 35’s new, what brand and if new were they mounted and balanced? I assume with a 4” lift you have adjustable control arms. Show some pics and did you get an alignment that you can post your results?
Old Jan 17, 2022 | 06:17 PM
resharp001's Avatar
Loved
Community Favorite
Reno, NV? Heck, just swing by TheDirtman's shop and he'll set ya straight. I'd guess there is no caster correction on that 4" lift and that ain't helping. If you happened to replace ball joints, new ones typically take a bit of time to break in.
As mentioned, pictures speak volumes. Hard to envision what you're working with otherwise.
Old Jan 17, 2022 | 07:21 PM
Big H's Avatar
Default Dirtmans shop
What is Dirtmans shop name. I'm new here. I changed out the hubs, tie rod, draglink, ball joints brakes. And yes I had it aligned, and rotated and balanced the tires. All Moog all brand new. Like I said I bought it with the lift and tires . So I don't know anything about the lift. Tires are falken a/t 35's. I don't have any pictures right now. Sorry. If you could get me to Dirtmans shop that would help. Thanks
Old Jan 18, 2022 | 03:45 AM
resharp001's Avatar
Loved
Community Favorite
Shoot @TheDirtman a PM. He's around regularly and should see the message. He doesn't talk about or promote business on the forums so I only know he's there in south Reno, but he's extremely knowledgeable and helpful so I have no doubt he'd help get you set straight.
Old Jan 25, 2022 | 07:01 AM
Willie1964's Avatar
I have the same problem! I replaced the tierod, drag link and track bar with Steersmart yeti equipment, got an alignment and it is terrible to drive. its parked until I can figure it out.
I'm gonna follow this post
Old Jan 25, 2022 | 10:14 PM
Mark Doiron's Avatar
Originally Posted by Big H
,,, 4in lift I think... the steering is worse than it was. ... it just wants to take off when it hits a rut in the road ...
May be bump steer. That much lift, you may want to install a drop Pitman arm, but check your steering stabilizer to ensure it is still working okay (some folks install an adjustable steering stabilizer and firm it up to "hide" bump steer). Here's an article on bump steer that may prove informative to you ...
https://www.naxja.org/html/techartic...psteertech.htm
