Vibration between 1000 and 1700rpm
Old Feb 17, 2022 | 03:00 PM
pivert's Avatar
Default Vibration between 1000 and 1700rpm
Hello,
I have a lot of vibration between 1000 and 1700rpm whatever the speed. I think it's due to torque converter in the 42RLE.
Do you think if I can replace the torque converter by a new one to solve this issue ? What model exactly ?
Thanks,
Ludo
Old Feb 18, 2022 | 11:11 AM
pivert's Avatar
I saw this proposal for 42RLE heavy duty:
https://www.atsdiesel.com/ats-42rle?...sociated=13899
Do you think if it's a good idea for the price or I should buy a standard rebuilt transmission ?
Old Feb 18, 2022 | 11:39 AM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
More info and detail is needed.. what year is your Jeep, mileage, how is/have you used, modifications? All these are needed to start with suggestions.
Old Feb 18, 2022 | 12:09 PM
pivert's Avatar
JK X 2007, 108 k miles
lifted with AEV 2.5" but the issue was present before in stock
run on 33" and 3.73 axles
Old Feb 18, 2022 | 01:22 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Could be crankshaft harmonic balancer going.
Old Feb 18, 2022 | 01:30 PM
pivert's Avatar
How to check it ?
Old Feb 19, 2022 | 12:38 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Usually you can see if it is misaligned when the engine is idling viewed from underneath. Or a magnetic dial gauge mounted nearby and asocket to rotate the crankshaft around while watching the needle on the dial. There is an outer ring of steel held to an inner core with a rubber insert in the middle. That rubber sometimes gets saturated with oil and deteriorates or you will see it bulging out.
Old Feb 19, 2022 | 01:03 PM
Mr.T's Avatar
Community Favorite
Lightbulb
Originally Posted by pivert
Hello,
Thanks,
Ludo
Do the 1000-1700 rpm vibes happen in park/neutral? If no, that rules out most balance issues like the front crank pulley/harmonic balancer. Do the 1000-1700 rpm vibes happen during immediate full throttle from a stop? It might actually be a shudder rather than vibration from the torque convertor's friction material during lockup -- Maybe just change the trans fluid???
Old Feb 19, 2022 | 02:00 PM
pivert's Avatar
No I feel the issue only during driving and nothing when the oil is cold. This is why I suspect the torque converter
Old Feb 19, 2022 | 02:47 PM
Mr.T's Avatar
Community Favorite
Lightbulb
Fluid and filter change might fix it, I'd try that before pulling the trans out.
