Lifted JK w/ Fox shocks…. Question about heim
Question - my passenger rear Fox shock bottom heim joint rattles when going over bumps.
Do you know of the heim unthreads from shock stem?
Welcome to JKF.. It would assist in getting a more accurate reply if you could provide the model of Fox shocks? How much Lift? Allow me to ask... is the shock heim loose on the bolt to the chassis?
Fox factory series
2 speed compression
4.5in lift
the bolt going through heim joint on bottom shock mount is tight. I push up on body and I can here the clunking. Not sure if ball in heim clunking or bolt clunking inside heim ball
they were on jeep when I bought, I can get a photo
2 speed compression
4.5in lift
