37's & 1350 je reel Cardin Driveshafts...Alignment
Just curious........
What did people running the 1350 Cardin CV Driveshafts and 37's set their alignment angles at?
toe in or out?
castor .. IE- Pinion angles
and what is recommended if any?
I set mine up and I think it is pretty good but still a little flighty
I have 1 degree toe in and my pinion angles are 2 degrees less than direct on the driveshaft. ( -3 castor )
toe in or out?
toe in or out?
toe in or out?
I was mostly concerned about the front u-joint prematurely wearing with a greater angle.... but now I realize "pushing" the front end into the pavement crippled my handling.
anyone else with a lift and your angles?
