questions about tires?
Old Oct 22, 2006 | 04:59 PM
alec789's Avatar
Question questions about tires?
what size lift kit do you need to put on a 2-door wrangler X to fit 33"x12.5" tires? what about 35"? thanks a lot
Old Oct 22, 2006 | 05:26 PM
wayoflife's Avatar
JK-Forum Founder
Hey alec789, welcome to JK-Forum.com. To answer your question, all you need to get to 33's is a 2" budget boost. For 35's, all you need is a 3" basic lift kit
Old Oct 22, 2006 | 05:34 PM
alec789's Avatar
any recomendations on lift kits? good price with good quality?
Old Oct 22, 2006 | 05:40 PM
wayoflife's Avatar
JK-Forum Founder
I have run half a dozen lift kits of different makes on my TJ and I can tell you from experience that the Full Traction kit I'm running now is hands down the very best one. The design and quality of the parts/welds are outstanding and the ride is better than stock. As far as price goes, their kits are right there with most of the competition if not a bit less. Depending on how much you can afford to spend, you can always start off with the 3" Economy lift and then upgrade the control arms and track bars as needed to make an Ultimate Lift Kit.
At least, that's what I'm planning to do
Old Oct 22, 2006 | 06:16 PM
dhoffroad's Avatar
yea what he said....I plan on doing the same thing the full traction 3" budget lift and 35's then upgrade from there....but eventualy I will end up with a 4" lift with 37's.
Old Oct 22, 2006 | 06:49 PM
ThinkMud's Avatar
33's will fit stock. Check this thread
JPFreak is running 285/75/16's witch = to be about 33's. I plan on putting 285/70/17's on mine, and that equals about 33x12.50 or 33x11.50 give or take.
so you can run 33's stock, but i'm pretty sure that you would rub during maximum articulation. So from what i've read the Budget Boost 2" lift would be best and eseasiest to install (and remove for warranty work ) You can order that kit for $119 from quadrotec, but i'd order you rims (if you are getting new ones) from Jegs.com, they were about 20 bucks cheeper per rim for my Crager Soft 8's. and they arrived in 2 days, free shipping.
Good luck and lets us know what you end up going with!
Old Oct 22, 2006 | 08:24 PM
wayoflife's Avatar
JK-Forum Founder
Oh, 4" lift and 37's are definetly on the to do list. And, I think you might be interested to know that I just spoke with Full Traction this afternoon and was told their 4" coils have been made and in reality yield more like 4.5" when all is said and done
Old Oct 22, 2006 | 08:25 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by yobuck
33's will fit stock...
Yup, they'll definetly fit but as mentioned by yobuck, they'll most likely rub on the trail too. Need I say, I'd still recommend at least a 2" BB for 33's
