How do I remove the Rear Axles
Old Jun 5, 2008 | 03:46 PM
mikesos1's Avatar
Question How do I remove the Rear Axles
Like the title says, I am installing a set of 5.13's in my Jeep. Got the front done no problem, but the rear is giving me trouble.
How are the rear axles retained, I have removed the 4 nuts on the back side of the axle flange and looked for C-Clips in the carrier. I can't figure it out. The axles are still in there good, no amount of pulling so far has even budged them.
It's a '07 Rubicon by the way.
Thanks for any help you guys can provide.
Mike
Old Jun 5, 2008 | 03:58 PM
Piginajeep's Avatar
they should just pull right out....
Old Jun 5, 2008 | 04:02 PM
NightStalker's Avatar
What we found out at SMORR is that a pry-bar might be needed. But, we were (I say we, I was watching) working on the front and the splines were tweaked a little and it took a pry-bar to get it out.
Good luck...
Old Jun 5, 2008 | 04:51 PM
mikesos1's Avatar
That's what I thought too. No Way, They are still in there GOOD.
Old Jun 5, 2008 | 04:52 PM
Northridge4x4's Avatar
Sponsoring Vendor
Slide Hammer.
David.
mikesos1's Avatar
Good luck...
I will give that a try, but there is not much to pry against.
Anyone else have any ideas?
Old Jun 5, 2008 | 04:57 PM
mikesos1's Avatar
Originally Posted by Northridge4x4
Slide Hammer.
David.
Thanks David, I spoke with you earlier. I don't have a slide hammer so I was looking for other alternatives. Looks like I am going to go buy one.
Thanks for the help.
Mike
Old Jun 5, 2008 | 05:03 PM
Piginajeep's Avatar
just get a rubber mallet and gently hit the backside...
Old Jun 5, 2008 | 06:01 PM
RedneckJeep's Avatar
A length of stout chain and a strong arm is all you need. Get about 36" of chain, attach each end to a wheel stud. Get plenty of slack in the chain and snatch that puppy right on out. Works everytime.
Old Jun 5, 2008 | 06:54 PM
davebloomer's Avatar
Im no help but WOW wish i had the know how or cahonees to replace my own gears.
