4" Terra Lift Body roll
Old Mar 10, 2007 | 04:03 PM
MBAR741028's Avatar
Default 4" Terra Lift Body roll
I just installed a 4" Terra Flex Lift with 35" tires and it has alot of body roll would stiffer shocks help.
Old Mar 10, 2007 | 04:38 PM
Ryan Graham's Avatar
Did you tighten all the control arms and things at ride height? Are you sure everything is tight? What are your tires pressures at?
Old Mar 10, 2007 | 04:44 PM
MBAR741028's Avatar
Everything is tight and the air is 34lbs.
Old May 8, 2007 | 06:30 PM
JK-RUBIJON's Avatar
I know that this is an old thread but I was looking into this lift for mine and was concerned about your experiance... any update?
Old May 8, 2007 | 06:32 PM
usmcdoc14's Avatar
stiffer shocks do not help with body roll, they just make a stiffer ride. a stiffer anti-roll bar would on the other hand.
