Cat Back Exhaust Removal
Old Aug 17, 2008 | 08:49 AM
69thunderbird's Avatar
Default Cat Back Exhaust Removal
Just wrestled with my exhaust for about 4 hours before finding out that you need a Hanger Removal Pliers to remove the hangars from rubber. not sure if it's possible to remove without them?
Having a lift so you can make good use of a rubber mallet (or sledge hammer) is very helpful too.
(A good power wash underneath so all the leftover trail material doesn't fall in your eyes would have been a good idea too)
Old Aug 17, 2008 | 09:28 AM
Zylfrax791's Avatar
A little squirt of Armor All and pull them off with your hands works for me...
Old Aug 17, 2008 | 09:33 AM
-MAW-'s Avatar
x 2
works great and to put them back on
Old Aug 17, 2008 | 09:42 AM
YingYang's Avatar
WD-40 works well. I pulled my Gibson off, pretty lound on long trips. When my JK is not my DD I will prob put it back on.
Old Aug 17, 2008 | 11:50 AM
riverzendz's Avatar
WD-40 did the trick for me on the hangars too.
They're a PITA though.
Old Aug 17, 2008 | 12:37 PM
aldaman's Avatar
That or dish washing soap...You can also use a large screw driver or a pry bar to help with the rubber hangars....
Old Aug 17, 2008 | 12:51 PM
horwitzs's Avatar
Large screwdriver for pry-bar with lube worked on some of mine,
Riciprocating saw took care of the others!
Old Aug 17, 2008 | 01:33 PM
RedneckJeep's Avatar
PB'Laster and a long pry bar.
Old Aug 17, 2008 | 06:04 PM
TINMAN080's Avatar
Saliva ain't bad.....
