Finally lifted
Old Sep 18, 2008 | 08:06 AM
MattMac1291's Avatar
Default Finally lifted
just wanderin i just put a 2.5 bb on my 07 sahara and wanted to see if i should put on wheel spacers so i sit wider or are they only needed when i go bigger tires?
Old Sep 18, 2008 | 08:08 AM
wayoflife's Avatar
JK-Forum Founder
you'll only need them if you get wider tires. if you are still running stock tires, you should be just fine as is
Old Sep 18, 2008 | 08:09 AM
thanks for the quick response ... yeah i was just askin cause i wasnt sure if it was a good idea to get a wider stance or not ... thanks again
Old Sep 18, 2008 | 08:12 AM
I couldn't get the swaybar links changed on my 07 Sahara without spacers even with stock wheels / tires.
wayoflife's Avatar
JK-Forum Founder
a wider stance is a good thing as it will lower your COG but in some areas, having your tires stick out past the fenders will get you in trouble with the local law enforcement. just something to consider.
Old Sep 18, 2008 | 08:13 AM
Ilovemy08jk's Avatar
I went ahead and got 1.5 inch spacers and I think it looks a little ber...but I also got wider fenders soI kinda needed them at the moment
Old Sep 18, 2008 | 08:14 AM
yeah that reminds me my passenger side rear sway bar link is like maybe a quarter inch from my rim is this normal .. its a tf 2.5 bb with shocks ... and will it be a problem?
Old Sep 18, 2008 | 08:19 AM
It should be a really big problem? are you running oversized tires?
Old Sep 18, 2008 | 09:43 AM
stock sahara size but yeah its no more than 1/4 " from the rim ... well the bolt for the link that is
Old Sep 18, 2008 | 10:11 AM
vwJarhead's Avatar
Don't need the spacers but the wide look is nice. This is a 2.5'' BB with 33x12.5 tires on 15'' wheels.
ID:	13014Click image for larger version
