Which Steering Stabilizer will Fit over ARB Covers?
I am having 4.88s and ARB covers installed next week. Wanted to add a steering stabilizer, but didn't know which brand fits over these covers? Thanks.
I am pretty sure you will be able to mount the SS at different angles to get it to clear (I am more worried about the stock tie rod at full turn my self) but I would recommend you do get the Woods SS relocation bracket so you can have more options.
X2 on the bracket. The Fox is probably the skinniest except for the stock one. I have spent a lot of time on this and my ARB still shows a couple of nicks in it. I'm thinking maybe the bracket that holds it on the rod needs to be ground off a little. on the cover side.
is there a reason why you want to upgrade your steering stabilizer in the first place? unless your factory unit is blown, an upgrade really isn't necessary. also, you shouldn't have any issue with a stabilizer and an ARB cover if it's mounted in the factory location.
