Warn Power interupt kit...
Old Sep 24, 2008 | 06:36 AM
mdmmd's Avatar
Default Warn Power interupt kit...
Has anyone installed this kit in their JK?
http://www.quadratec.com/products/92126_05.htm
If so, where did you mount the Solenoid? I'm having trouble finding a place where it wont short on another metalic (grounded) portion of the chasis. I was thinking on the side of the battery box but its a little flimsy. Thanks
Old Sep 24, 2008 | 09:49 AM
rickl's Avatar
built my own with better parts that cost less(approx $40cdn) for 600amp continous duty solenoid,nicer looking switch,wire and cable ends,mounted solenoid right next to battry hold down clamp,mounted switch in daystar switch panel already installed,took switched power for switch from cig lighter on lhs(also powers my ipod)have winch in/out switch(robbed from spare remote)mounted in the old cig lighter location and wired in to winch solenoid box which gives me in cab control of winch without running remote in thru the window
Old Sep 24, 2008 | 12:47 PM
ranwitscissorz's Avatar
When I mounted the selonoid I lifted off the top of the fuse box, just to make sure my screws didn't go down into them, but there was still plenty of space, I think I used 2 inch self tapping screws. Let me know if this helps.
ID:	13231   Click image for larger version
Old Sep 24, 2008 | 02:08 PM
tambil68's Avatar
sounds like a sweet setup. How did you hook it up to the winch?
Old Sep 25, 2008 | 07:33 AM
rickl's Avatar
how did I hook up second(dash mount)controller to winch?right now I have the lead with original plug tied up by solenoid box,plug in remote otr cab control as required,but next time I pull my grill(solenoid box for warn M8000 mounted behind grill)I am going to hard wire it in parralel with socket for remote
Old Oct 27, 2008 | 04:29 PM
rickc309's Avatar
I got my Warn interupt solinoid installed, just need to find a keyed power source under the dash.. I made a bracket to hold the soliniod, it fits between the battery and fuse box. I'll post pic's soon.
Old Oct 27, 2008 | 06:18 PM
tgrt's Avatar
Former Vendor
Here's where I put mine:
http://www.flickr.com/photos/tgrt/2446726102/
