Rear Sway bar question
Old Oct 8, 2008 | 08:48 AM
nachoninja's Avatar
Default Rear Sway bar question
I'm waiting for my OME 2" medium duty lift to come in and I purchased a set of stock rear sway bar links from a forum member to replace my stock front links because I've got a Rubicon and read problems about the fronts being too short. Now that I'm looking at the back links I'm wondering, will it be okay if I leave the stock links on? It looks to me like the end of the sway bar will not sit level with the ground after 2" of lift.
Thanks.
Old Oct 8, 2008 | 09:17 AM
Robar's Avatar
I have been running the stock rear links with my OME life and have had no problems at all.
Old Oct 8, 2008 | 09:53 AM
nachoninja's Avatar
Did you replace the front links? Just wondering if there will be any issues caused by my rear sway bar not sitting level.
Old Oct 8, 2008 | 10:01 AM
Jeepin Dad's Avatar
I have a 2" lift with stock rear swaybar links on both the front and the back and havn't had any issues.
Old Oct 8, 2008 | 10:33 AM
Robar's Avatar
I replaced my fronts with the JKS Quicker disconnects, but you should be fine with the rear disconnects on the front.
Old Oct 8, 2008 | 10:50 AM
wayoflife's Avatar
JK-Forum Founder
Thanks.
yep, you'll be just fine with stock links in the rear.
Old Oct 8, 2008 | 11:32 AM
nachoninja's Avatar
Sweet, thanks for the help guys.
Old Oct 8, 2008 | 08:04 PM
randyd's Avatar
If you got a kit from Terra Flex, it would have everything you need in it, and it all fits....
Old Oct 9, 2008 | 02:20 AM
backdoc94's Avatar
The rear sway bar looks pretty small, is is a big problem to just remove it? Does it really make that much difference?
