TPMS sensors + Staun "Beadlocks" ??
Old Oct 9, 2008 | 03:09 AM
w squared's Avatar
Default TPMS sensors + Staun "Beadlocks" ??
Does anyone know if the TPMS sensors can be fitted to wheel that are equipped with Staun "Beadlocks"?
I think that the stock DC TPMS sensors are the valve stem type (but I don't actually know). Would this interfere with Stauns or be interfered with by the Stauns?
I suppose that you could always build a pressurised container to stash all 5 TPMS sensors in. Would PVC pipe with a good marine epoxy in the threads and sealing a valve stem hold 37 PSI?
Ah...there's the answer to my "pipe" question...
http://www.clublexus.com/forums/showthread.php?t=328044
I'm pretty good about checking tire pressure, so I think I can live with that solution. It'd be nice to reprogram the TPMS to a good pressure for DD duties though.
Last edited by w squared; Oct 9, 2008 at 03:14 AM. Reason: Answered one question myself...
Old Oct 9, 2008 | 03:36 AM
knotaddicted's Avatar
Thats a pretty slick solution to the TPMS sensor problem.
Old Oct 9, 2008 | 04:15 AM
BaltChief's Avatar
This "solution" won't work with the JK. The stock sensors are activated by tire rotation, so unless you can figuire a way to rotate that there cannister at the speed of your tires it will not read.
Just call your dealer or a few tire stores and find one that has one of these, http://www.artsautomotive.com/TPMS.htm and get your sensors set lower. The stock sensors can be set as low as 28psi, if you want lower buy some aftermarket ones designed for lower psi.
Old Oct 9, 2008 | 06:59 AM
VictorS's Avatar
With respect to the STAUNS, the TPMS cannot be fitted. Staun supplies a special valve stem to be used in place of the stock valves. You will be drilling a second valve hole in your wheel rims for the secondary valve which is connected to directly to the Staun inner tube.
Old Oct 9, 2008 | 11:09 AM
Ipe's Avatar
Ipe
Your answer is both incorrect and possibly correct. I'm running Staun IBL's in my wheels with the TPMS and have no issues. The TPMS works as advertised (ie: its a PITA) and the separate valve stem is just that, a separate valve stem. The Staun "special" valve stem is only special in that it has a deeply grooved head to allow air to pass in the valve channel flap. having the TPMS makes that unnecessary as the valve stem itself in the TPMS is underneath the TPMS body, on the rim side. This allows all the air flow you'll need (provided the Staul IBL is installed correctly).
The possibly correct part is that Staun recently changed to a different style of valve channel that makes installation easier. This version would prevent installation of the TPMS as you typically would. However, if you found a way to mount the sensor inside the tire cavity not occupied by the Staun IBL, then at least in theory, the TPMS should work. If a "pocket" were sewn onto the outside of the IBL casing, or if the new casing already incorporates this, then you could just place the TPMS in that pocket and you'd be all set.
