3" Lift plus 35's = Driveline issues???
Old Oct 9, 2008 | 05:13 AM
Coach's Avatar
Default 3" Lift plus 35's = Driveline issues???
I am getting ready to purchase the Zone 3" lift kit and put on 35's. I have tried several searches, but have not gotten the info I am looking for. Will the lift plus tires cause driveline issues under normal offroad conditions. No extreme rock crawling. I have an Unlimited w/6spd and 4.10's. Thank you for any help.
Old Oct 9, 2008 | 05:18 AM
wayoflife's Avatar
JK-Forum Founder
no. being that you have an unlimited with a 6-speed, you will be just fine.
BTW - just out of curiosity, can i ask what made you decide to go with this kit?
Old Oct 9, 2008 | 06:17 PM
dpoelstra's Avatar
just a note...
tire size will not effect drive line angles, and most report problems with drivelines on lifts over 4 inches.
Don't go forward based on the stated lift, rather than the measured lift. 3 inch springs will most likely give you 4 inches of measured lift (mine did) and many 4 inch lifts have given reported 5 inches and more.
I have 3 inch springs that have a real measured 4 inches of lift, and I have had no drive line issues over 17k miles.
Old Nov 17, 2008 | 07:01 PM
joneszj's Avatar
Default Same question, but have a 2 door
So I am new to the forum and after a year running stock, I have gotten the itch to get working on my JK. I am also looking at the running the Zone 3" lift with 35s. I also would like to add a 3/4" or 1" body lift for extra clearance. I have a 2 door x, 6speed and was wondering what other issues i should deal with before getting the lift... re-gearing, disconnects, trac-bar, control arms? I have looked at many posts and can't seem to find a solid answer...I generally drive highway miles and go wheeling on mostly mild trails, no rock crawling. Please let me know any suggestions, basically I want to have a good ride quality but have better off-road ability.
Old Nov 17, 2008 | 07:06 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Originally Posted by rob4607
Don't know his reason but they are on ebay pretty cheap if I remember right.
Just keep in mind that you get what you pay for!
Old Nov 17, 2008 | 07:36 PM
wayoflife's Avatar
JK-Forum Founder
being that you have both a 6-speed and an unlimited, no, you will be just fine with your factory drive shafts and will not need to replace them.
Old Nov 17, 2008 | 08:04 PM
RedrockX's Avatar
i've been wanting to ask this, but never have...
"usually" the driveshaft on a manual tranny is LONGER than an auto.
so, are the driveshafts for the JKs the same for both?
(not 2dr vs 4dr)
manual shaft (2dr) vs auto (2dr)
Old Nov 17, 2008 | 08:12 PM
RedrockX's Avatar
the REAR shaft...
i know the fronts are the same.
Old Nov 17, 2008 | 08:17 PM
wayoflife's Avatar
JK-Forum Founder
this is my opinion as well.
(not 2dr vs 4dr)
yes, the drive shafts are the same on both an auto and a 6-speed.
Old Nov 17, 2008 | 08:21 PM
RedrockX's Avatar
ok cool...
