how long can I go?
Old Oct 29, 2008 | 04:29 AM
jayrav's Avatar
Default how long can I go?
I recently lengthen my front LCAs looking for more caster. Superlift & Teraflex recommend 23.25". Mine are now 24"driver 23.75 passenger. I have the driver side longer to help relieve left drift. Didn't work. Still drifts to the left. That's another story. Besides the drift I'm not happy with the handling.
Are my LCAs too long?
Old Oct 29, 2008 | 07:45 AM
greenmachine07's Avatar
well di you look at the toe in, adj. steering wheel, upper CA, rear CA, Adj trackbar. any one of those could be your problem
Old Oct 29, 2008 | 08:35 AM
jayrav's Avatar
The rear CA's are fine. They are at superlift specs.
The steering wheel is centered.
The front upper CA's are good. They are at Superlift specs.
I plan to revise my front trackbar more thoughly. I gave it a pull to see if it was loose. No movement. Now I have to see if there is any movement lock to lock.
My toe was adjusted to 1/8" then I had it changed back to factory specs. I plan to revise the toe.
Tomorrow I'm having a offset ball joint installed to fix the passenger side camber. There we can give a look over everything else. I feel like readjusting the front LCA to Superlift specs(23.25").
Any other suggestions?
Thanks!
