what size Gear Are recamended for 35" tires
Old Dec 7, 2008 | 08:27 PM
08jk4door's Avatar
Default what size Gear Are recamended for 35" tires
i have a 08 4 door X with the dana 44 in the rear and the 30 in the fron and want to lift it for a set of 35" tires but i need to know what gear should i use to still have a driver and a fun time on the trails ?
Old Dec 7, 2008 | 08:45 PM
moabjk072d's Avatar
I agree, I am putting in 5:13's this week and I have 35's and a auto.
Old Dec 7, 2008 | 08:52 PM
chuck45's Avatar
Originally Posted by redx08
most people on here recommend 4.88 for 6spd and 5.13 for auto
Correct. I've got the auto with 35's and 5.13's work great. 4.88's are fine with the stick, unless you plan on going to 37's in which case you should go with the 5.13's.
Old Dec 7, 2008 | 09:03 PM
08jk4door's Avatar
ok sounds like it will be 5.13s thank you for the help
Old Dec 8, 2008 | 03:14 AM
JulietKilo's Avatar
5.38's ...........
Old Dec 8, 2008 | 04:20 PM
chuck45's Avatar
Originally Posted by JulietKilo
5.38's ...........
Well that would cure the power issue for sure! Especially if he has a 6 speed.
That calculates out to 3300 at 75 mph with a 6 speed. It would be great for towing a trailer though.
Old Dec 8, 2008 | 09:20 PM
cub23's Avatar
Does it make a difference 2 door or 4 door?
Old Dec 8, 2008 | 09:30 PM
chuck45's Avatar
Only in the sense that a 2 dr is lighter than a 4dr. And that is referring to the bare vehicle. You can also load a lot more gear in a 4 dr so ultimately the 4 dr can get a lot heavier than the 2 dr. It also makes a difference as to whether you're at sea level or in the mountains of the West.
Old Dec 9, 2008 | 05:24 AM
tgrt's Avatar
Former Vendor
You'll be happy with the 5.13s in an automatic.
