Rugged ridge side armor clanging?
Old Dec 9, 2008 | 02:18 PM
paranoid's Avatar
Default Rugged ridge side armor clanging?
Has anyone else had this problem. I have them on my o7 rubi with the rubi rails still on. I called tech for rr and they said they would get back with me...... that was two weeks ago. Just wondering if anyone found an easy fix.
Old Dec 10, 2008 | 12:58 PM
paranoid's Avatar
Anyone at all?
Old Dec 10, 2008 | 01:46 PM
BriTine's Avatar
I had the same issue. I put a small piece of rubber between the side rail and the rubicon rail. Once I snugged up the bolts it holds the rubber in place and no more rattle.
I actually cut up this -Click image for larger version
Old Dec 10, 2008 | 04:13 PM
wayoflife's Avatar
JK-Forum Founder
unfortunately, i am not familiar with this side armor but, do you happen to have an idea what is clanging? is it making contact with your rubi rails?
Old Dec 10, 2008 | 07:57 PM
drcre8tive's Avatar
Default Rugged Ridge side rattle: What exactly?
I actually cut up this -Attachment 16394
To overstate the obvious, What exactly is that, and where did you get it?
Old Dec 10, 2008 | 11:36 PM
09rubicon's Avatar
That is an oil filter wrench and you can get them at about any auto parts store for anywhere from 5-15 bucks.
Old Dec 11, 2008 | 02:16 PM
BriTine's Avatar
The tool (Craftsman) is from sears the loop is made from thick rubber it is about 1/4 inch thick. You could use is it remove your oil filter. I have used it for turning plastic plumbing parts under my kitchen sink.
Old Dec 12, 2008 | 07:21 PM
paranoid's Avatar
I think it is hitting the rubi rails it is a very small gap that is between them. I have tryed to make it make the sound myself but no luck. Once you get on the road and hit a sharp bump there it is though. I will try the pieces of rubber and see if that works
