Need help leveling out my jk! a quick fix??
Old Dec 11, 2008 | 07:10 PM
still1graphics's Avatar
Question Need help leveling out my jk! a quick fix??
ok here's the deal... i put a 2" rough country spacer lift on my jk, it is a 2.5" on the front and a 2" spacer on the rear, but its still an 1" or so low in the front?? i hate the saggin' look. could it be my winch pulling it down, rough country says it should level it out, but no luck! is there anything i can do to fix this?? a quick or cheep fix w/o putting a whole new suspension kit on! does anyone make a 3" spacer or something?? thanks for any help or advice!!!
Old Dec 11, 2008 | 07:13 PM
JK-KJ's Avatar
rough country sells 3/4" spacers for about $55....i put some on mine. you could stack that on top of the 2.5" maybe.
Old Dec 11, 2008 | 07:20 PM
can you do that?? has anyone on here done that, i did install the shock extenders that came w/ the kit.... i was thinking of adding another spacer, but didn't know if it would pose a problem or not?? any help or advise from someone that has done this would be great!!!
Old Dec 11, 2008 | 07:30 PM
jeepnyak's Avatar
I have the 2.5" tf kit and after my steel bumper it became nose heavy. I added the .75" spacer on top with no problems since. almost a year now. I still have a little rake. I'd go with the 1" teraflex spacer for best results. After a while you springs will sag b/c of the weight.
Old Dec 11, 2008 | 07:57 PM
Dylanjam77's Avatar
Could also swap out your springs for longer, heavier duty springs also as opposed to stacking spacers.
Old Dec 12, 2008 | 05:03 AM
JK-KJ's Avatar
i've done it..but mine are 3/4" stacked on top of 1.75" spacers....havent had any problems though and it leveled mine out perfectly.
Old Dec 12, 2008 | 02:33 PM
Question
so, since mine are already 2.5" in the front will it be ok and safe to add the 1" from teraflex on top?? is there anything i need to know before doing this?? this would be the cheapiest and fastest way to do it, just wont to make sure its safe??? the wifey drives it some too w/ the little ones! thanks guys!!!
Old Dec 12, 2008 | 02:46 PM
jtphoto JK's Avatar
It's just as much work to add a spacer as it is to put new springs in. I would (and will be
) going to 3" TF springs up front to level out my JK. Do it once and do it right.
Old Dec 12, 2008 | 02:47 PM
mattb2179's Avatar
just take the spacer out of the back.
Old Dec 12, 2008 | 02:49 PM
if it took it out of the back the tires would rub!!
