other lifts to come?
Old Nov 10, 2006 | 04:43 AM
paroxysym's Avatar
Default other lifts to come?
i was wondering if anyone knew if other lifts were to come? like something from OME or RE. nothing long arm, something short arm or around 2". the reason i ask is that with the rock rail issue i have seen im thinking im gonna run a 305/70 on a set of stock rims, which i think would look good to accomplish that short squatty look i have always wanted in a jeep. plus the jk is already kinda wide and squatty as far as the tub goes. any ideas?
Old Nov 10, 2006 | 06:13 AM
paroxysym's Avatar
Originally Posted by 2k2wranglerx
That's what i'm doing. But i made my lift lol. Did you see the pics?
yes i did. 4" is a bit much, like the set up though.
Old Nov 10, 2006 | 08:34 AM
wayoflife's Avatar
JK-Forum Founder
I've talked to ARB/OME and was told they might have a lift out by Off Road Impact which is in January. Although, why not just install a 2" spacer lift like what Full Traction or Teraflex makes?
Old Nov 10, 2006 | 08:54 AM
paroxysym's Avatar
well see here is the thing bro, i like the spacer lifts but if they come out with a coil lift ill buy that instead. which of the spacer lifts gives less lift? im just looking to run 33s with not a huge amount of space between the tire and the wheel well. i want that short/sqautty look.
Old Nov 10, 2006 | 10:20 AM
wayoflife's Avatar
JK-Forum Founder
I believe the TeraFlex spacer lift will give you 2.5" of lift and the Full Traction just 2".
Old Nov 10, 2006 | 10:34 AM
paroxysym's Avatar
wont 2" be alittle much for 33s? im thinking like a 1" with some OME shocks smooth as a babies butt
Old Nov 10, 2006 | 10:44 AM
wayoflife's Avatar
JK-Forum Founder
Ya know, you can practically fit 33's without any lift at all. You may experience a little rubbing at a full turn and on the trail but that's about it. Certainly nothing a little trimming can't fix
Old Nov 10, 2006 | 10:51 AM
paroxysym's Avatar
eh id rather not trim.
Old Nov 10, 2006 | 11:10 AM
wayoflife's Avatar
JK-Forum Founder
But that's just the thing, you most won't have to
Old Nov 10, 2006 | 11:13 AM
tcpatter's Avatar
I don't know if the spacers are the same between the front and back or not, but skyjacker has 3/4" front spacers here. If they are the same (which I hope someone can answer) then you could get almost an inch of lift for about $60.
