other lifts to come?
i was wondering if anyone knew if other lifts were to come? like something from OME or RE. nothing long arm, something short arm or around 2". the reason i ask is that with the rock rail issue i have seen im thinking im gonna run a 305/70 on a set of stock rims, which i think would look good to accomplish that short squatty look i have always wanted in a jeep. plus the jk is already kinda wide and squatty as far as the tub goes. any ideas?
JK-Forum Founder
I've talked to ARB/OME and was told they might have a lift out by Off Road Impact which is in January. Although, why not just install a 2" spacer lift like what Full Traction or Teraflex makes?
well see here is the thing bro, i like the spacer lifts but if they come out with a coil lift ill buy that instead. which of the spacer lifts gives less lift? im just looking to run 33s with not a huge amount of space between the tire and the wheel well. i want that short/sqautty look.
JK-Forum Founder
JK-Forum Founder
Ya know, you can practically fit 33's without any lift at all. You may experience a little rubbing at a full turn and on the trail but that's about it. Certainly nothing a little trimming can't fix
