Need help picking out lift..
Money is an object, so your thoughts on the full traction, black diamond, and teraflex 3" lifts for my Wrangler X... I know full traction has 3 versions of their lift, but I'd like to keep it under $1k if possible. Thanks, Matt
Now, with that said. I like my Skyjacker kit, I'm just going to brace the rear bracket no matter what and it's nothing new, TJ's had the same problem.
Thats what I was thinking.. I could also add adj control arms via daystar or teraflex later on, to make it even better at a later date right? How are the shocks that come w/ black diamond, th eride quality?
Yeah, I plan on adding adjustable upper and lower arms later which will render my Skyjacker lowers useless. Check out cablerep79's gallery. He has a good setup, kind of sounds like what you might be looking for and he's using 15's that work for sure.
I can't tell you about the stock BD shocks though. I went with Skyjacker Nitro's primarily based on what other's had wrote about them. I also didn't install the cam bolts that came with the kit used to adjust caster because I anticipated adding adjustable arms later but after seeing how it rides, I doubt I'll be buying them now. My ride is not much different from stock and I didn't need an alignment afterwards. If you decide to go with BD though, I doubt you'll need the extra 3/4" spacers up front. I'm taking them off this weekend. I also replaced the stock exhaust today with the Dynomax cat back system.....it's nice to be able to hear the exhaust again!!
$233 with shipping from 4wd.com. It was hell getting the stock exhaust out but only took about 15 minutes to install the dynomax. I like the sound of it, haven't driven enough to notice any performance gains but don't really expect to see many until I buy a CAI.
