Let's see your racks!
Old Jan 7, 2009 | 06:49 PM
SaginawMike's Avatar
Default Let's see your racks!
Cargo racks that is. I'm looking at putting a full cargo rack over the roof area for my 2dr. If you would post a picture and state the brand name and any pros and cons I would appreciate it. Thanks
Old Jan 7, 2009 | 06:56 PM
Dylanjam77's Avatar
Was gonna say... isn't that a DIFFERENT thread?!?!?!?!
Old Jan 7, 2009 | 07:06 PM
RAM's Avatar
RAM
It's a thule feet with utility bars. You can add a basket, but I use mine for ladders, fishing rods, etc. When I dont need them I simply remove the bars and put covers on the boots.
Old Jan 7, 2009 | 07:11 PM
Looks good but I don't think that will work too well on my soft top.
Old Jan 7, 2009 | 07:35 PM
YellowToy's Avatar
This won't carry a canoe, but here you go...
Old Jan 7, 2009 | 07:42 PM
Won't or can't?
Old Jan 7, 2009 | 08:19 PM
scouter4life's Avatar
Here's my Warrior Products Safari Rack. The 2 door version is just shorter. Nice thing about this rack is the basket can be removed and the front and rear bars left in place. They have tabs for 4 lights in the front and 2 in the rear if needed. The only downside is that the rack does not tilt out of the way to drop a soft top, but I've found I can remove mine pretty easily without taking the rack off. Putting it back on is more of a challenge, but still doable.
No basket:
Front view:
close up by the top:
Rear mounting points where you drill into the body, but I just put RTV around it to seal it and it's been great. I'll be adding corner guards at some point as well and will make it that much stronger.
empty:
Full, I've set it up to carry as many as 7 bikes:
Old Jan 7, 2009 | 08:26 PM
lowspeedchase's Avatar
Old Jan 8, 2009 | 02:43 AM
Jeepin Dad's Avatar
Here is the 2-dr version of the Warrior rack. Like scouter4life said working the soft top with the basket on could be a little difficult since it doesn't tilt. Most of the time my basket hangs in the garage, it is light weight and comes on and off pretty easily.
Empty
Loaded
The rear light tabs make for a good place to mount a Hi-Lift up out of the way.
Old Jan 8, 2009 | 02:47 AM
Soup's Avatar
What are those spacers/support/grab handles on the inside? did you fab those yourself or are they from Thule with the feet???
[/QUOTE]
