15 inch wheels will or will not fit?
Old Jan 8, 2009 | 05:51 PM
jksmith's Avatar
Default 15 inch wheels will or will not fit?
i talked to a guy at quadratec and he said that since my jeep camewith 16inch wheels that a 15 inch wheel will not fit. but ive seen people on here who run 15s? whats the truth? and if you use a spacer it wouldnt matter at all would it?
Old Jan 8, 2009 | 07:36 PM
2climbbig's Avatar
some wont fit others will. I have uniques and they fit just fine.
Old Jan 9, 2009 | 01:53 AM
pearl-drum-man's Avatar
Some will also fit with some minor brake caliper modding. There are a number of threads on this which will give you a good idea of which ones do and don't work.
Old Jan 9, 2009 | 03:19 AM
awdspider's Avatar
through out all my searching ....when i was looking for the very same answer most recomended a wheel with 3.75" backspacing. that is what i have and it fits fine.
-shaun h
Old Jan 9, 2009 | 04:32 AM
NYJKGUY's Avatar
I have 15" wheels i forgot the back spacing i got the from 4 wheel drive hardwear in early 07 they work great
Old Jan 9, 2009 | 04:45 AM
Captain Hook's Avatar
I have 15's with 3.75 BS and they fit just fine as well.
Old Jan 9, 2009 | 05:08 AM
HappyCurmudgeon's Avatar
Eternal ***erator
to my knowledge it is partly a fitment issue due to backspacing, and the caliper hitting the bead ridge on the inside of the rim. No 2 Mfg's seem to make them the same...
I thought there was a thread around here somewhere that listed the Mfg's wheels that seemed to be ok & the ones people where having intermittant problems fitting?
apparently I am search stupid today because i cant find it.
Old Jan 9, 2009 | 03:51 PM
casaintsfan's Avatar
me too
procomp series 97's 15x8 w/ 3.75 back spacing
Old Jan 10, 2009 | 05:49 AM
Mo-mud's Avatar
This is my setup 15x10's with 4.6 BS on 35' Claws..I like the wider stance.
https://www.jk-forum.com/forums/modified-jk-tech-2/procomp-8179-15x10-test-fit-50608/
Old Jan 13, 2009 | 01:47 PM
bone's Avatar
Originally Posted by casaintsfan
me too
Mine too. Same back spacing as above, 3.75 on 15x8. Mine worked fine. I ordered Pacer Street Locks first and they wouldn't clear the breaks. I called Sam's Off Road in Tulsa and they recommended a wheel that worked out great. They are American Eagle 15x8's. Not sure what the series number is. See pic.
