609 Axle
Old Jan 21, 2009 | 06:24 AM
BigTexRedneck's Avatar
Default 609 Axle
HAs one built one for the JK?? I have the money to do it but I have yet to build an axle yet but plan to soon once I get home
Old Jan 21, 2009 | 06:55 AM
David @ Currie Ent.'s Avatar
Former Vendor
Yes, we do them all the time. Maybe you could use one of our new fabricated housings!!!!! You will see our 2dr sporting New Fabricated Housings soon!!!!!
Old Jan 21, 2009 | 07:13 AM
JK GABY's Avatar
You have preview photos of the RED JK 2DR LONG ARM before MOAB
Old Jan 21, 2009 | 01:50 PM
TBEASLEY's Avatar
whimp.............try diamond housings with mega hi9's
Old Jan 21, 2009 | 02:17 PM
JulietKilo's Avatar
For those of you that dont know what a 609 is...
Dana 60 knuckles
+ Ford 9" third member and/or center section
= 609
EDIT:
WHY: You get the best of both worlds. One Ton strength on a commonly available Axle Housing
ADVANTAGES (Over a complete Dana 60 Front axle):
Availability. Dana 60 Front axles are getting scarce, and are very expensive new.
Ground clearance. The 9" hangs 5-7/8" below the axle centerline at its lowest point. The Dana 60 is 6-1/4". The custom "High clearance" Currie housing pictured above is trimmed to 5-9/16". A Dana 44 is 5-3/8".
Weight. The Ford 9" is lighter than a Dana 60.
Drop out center section. The 9" is very easy to set up gears and change the third member out.
Availability of a High Pinion third member. This axle utilizes a "high pinion" arrangement where the drive shaft enters far above the axle centerline. Up out of harms way. A Dana 60 was available with a High Pinion in Ford F350's. Expensive hard to find, and the differential is on the wrong side for a Jeep CJ.
Cost. 9" housings and components (gears, lockers etc) are priced significantly lower than Dana 60 (and even Dana 44) parts.
Old Jan 21, 2009 | 03:42 PM
David, do you have a link to where on y'all site I can find this?
Old Jan 21, 2009 | 08:01 PM
LoPo's Avatar
How much cheaper are they?
Old Jan 22, 2009 | 10:46 AM
TBEASLEY's Avatar
they really arnt...........especially if you want the esp/abs to still work
for about the same strength(probably more) and less money you could build
d44 center chunk/ 3/8 wall tubes
deadenbear dana 60 knuckles and inner c's for
35 spline arb locker
35 spline longfield super axles
dynatrac super stub hub and a set of spider trac cromo drive slugs
that would be pretty much bullet proof with the v-6 and any size tire
now for a hemi............ i think i would want a bigger ring gear
Old Jan 22, 2009 | 11:24 AM
TBEASLEY's Avatar
Originally Posted by cdc12372
WOW........ That is a BIG statement...... comparing a Dana 44 to 9"
I'll like to see a 44 hold up to 1,200 hp, 9" do it all day long
no sir.........
low pinion std rotation 9's live like that.............
low pinion 9's suck for the front of a jeep and they would have to run RR
for the front of a 4x4 a HI9 center chunk needs to be used.............thrust loading becomes a very real problem.........true hi9 and currie have solutions to deal with this and it works!!! but it makes the assembely weaker and the third member is very expensive
also those 9's that deal with big power are solid, with 40!!!! spline axle shafts
now what i was getting at was the strength/ cost ratio........behind a v6/auto/atlas............
a 609 built with true HI9 chunks and all the right parts would be stronger but lots more money and a bit of overkill
for a hardcore jk on 40's or 42's a hybrid 44/60 would be super stout and less expensive
Old Jan 22, 2009 | 12:40 PM
freshjk's Avatar
I'm a real big fan of the 609's! Can we get some more pics Currie
