heavy mods
Old Jan 27, 2009 | 10:11 AM
White Widow's Avatar
Default heavy mods
has any one went custom suspension?
soon i am ditching the dana 44s and rancho tri link. im ready for the good stuff, dana 70s and for suspension, triangulated four link f/r and coilovers f/r.
my concern is the rear tri 4 link in the rear. i am not sure if this is possible because of the long gas tank. is the gas tank is in the way do you think extending the wheel base will bring control arms up enough to clear gas tank. or will i have to end up tossin the back seat and running a fuel cell. i have the 2 door jk by the way.
Old Jan 27, 2009 | 10:15 AM
one more thing does any one know what the esp will do. i think the lights will just turn on and thats it but may be wrong.
Old Jan 27, 2009 | 10:40 AM
Very interesting.....
I was actually thinking of using the Full Traction brackets and having Venom Customs make the control arms with Johnny joints at both ends....and bending the arms for better clearance like in the old nth degree tj kits.........
also, There is a shop in utah that made a tri 4-link for a jk by removing the muffler/exhaust and placing the two upper links from the very back of the frame (like from the rear bumper area forward) to a truss system on top of the diff housing.....
Old Jan 27, 2009 | 11:49 AM
thats pretty much what im running now
Old Jan 27, 2009 | 12:10 PM
webekd's Avatar
Go to the Rock Krawler site and see if that is what you are looking for. Look at the TRIPLE THREAT LONG ARM SYSTEM.
http://www.rockkrawler.com/
Old Jan 27, 2009 | 12:18 PM
Worthless's Avatar
Ill be tackling this project soon myself. With that massive tumor of a gas tank there is no reasonable way to go tri 4 link in the back with reasonable 4 link numbers even if you stretched it a foot. If it had a metal tank you could have a better chance of getting it done, but you don't. You could run a long arm setup with a radius arm type suspension but you would still be stuck with that track bar and it sounds like you are trying to get rid of it. What coilovers are you thinking about going with? The esp is most likely going to freak out so you'll have to bypass that. Why dana 70's, why not 60's? Bottom line, go fuel cell and be done. Remember you have evap that you need to keep happy
Old Jan 27, 2009 | 12:48 PM
MBATF's Avatar
Sponsoring Vendor
Alpha Expedition
Give at call to Mel At Offroad Evolution. They have killer systems with crazy flex that's' almost stupid for both your front and rear.
Old Jan 27, 2009 | 01:22 PM
RDY4RKS's Avatar
Sounds like an interesting project. Good luck.
Old Jan 27, 2009 | 04:30 PM
TBEASLEY's Avatar
i would like to meet the guy that NEEDS d70's in a jk.....ie:breaks d60 stuff on a regular basis with this mini van engine
oh yea and i know of 2 jk's in texas being converted to tri 4 links and coilers with ford axles
Old Jan 27, 2009 | 05:06 PM
Originally Posted by YOGURT
Why cant you ditch the stock fuel tank, take out the recessed trunk then place a fuel cell or custom tank at the rear like the TJ. Then you have all the room you want .
because i want to stretch the wheel base
i want 70s cause they are stronger duh 60s are cool but most of my friends are running 70s so we could swap parts plus my friend is always coming across 70s.
its going to be an ohv with 40in+ tires soon (hopefully) so why not
ya i may end up having to go fuel cell or custom 5 link booo
