Hardware for Bikini
I will have the Freedom Top and am looking at also running with a bikini. I have a handful of questions:
1) If you put the winshield rail in for the bikini, do you have to take it off in order to put your Freedom Top back on?
2) Is there a specific bikini top you have to order if you go with the soft top door rails (to give a better seal)?
3) What is the cost of the door rails?
4) I assume the door rails would need to come back off when reinstalling the Freedom Top, is that correct?
5) How difficult is it to install/remove the door rails?
Thanks for your input.
the windshield rail stays on the bikini,, its nothing like the TJ designs. You do not need the soft top door rails, but you are right it definetly will seal the doors. If your dont have the door rails (surrounds) they wont seal.
Door surrounds come on and off in about 5 secounds. theres two big screws the go through the roll bar. its very easy.
hope this helps
And yes the bikini comes off before you can put the hardtop back on, door rails too.
And I think the bikini looks better than running the hard top panel, but they do the same thing, keep the blairing sun off your head.
Thanks for the suggestion though, I may experiment w/that to some degree.
hope this helps
hope this helps
I think I will probably go with just the bikini, no door surrounds... I tend to run w/out the doors anyway. Plus I'll throw a trail cover in the back just in case I'm somewhere that doesn't have covered parking
Come on, someone has to have a bikini top that runs the Freedom Top as well???? :confused:
